The solid label is because the tools assign any volumes a solid label and unlabelled surfaces in Fluent Meshing can then inherit that name. You'll have missed a surface somewhere when setting the named selections. I wouldn't expect to see the odd cell clustering at the trailing edge so check the surfaces and surface mesh in that region. nRe the Workbench Meshing images, check the edge sizing you've assigned and also the surface mesh option and source face for sweep:it looks like some constraints are clashing. n
