1shan
Hello @nyla,nHave you tried using ECENTX? I am not sure if you can scope it to a flexible body. If it works then you are right. You may check this https://www.padtinc.com/blog/wp-content/uploads/2018/04/PADT-ANSYS-Mechanical-Extracting-Relative-Displacements-20180404.pdf. An easier (but slightly less accurate) way could be to use a remote point scope it to the outer surface, set the behavior to deformable and use the deformation probe scoped to remote point.nRegards,nIshan.n
