DrAmine
You run a stationary simulation and in fact you specified a wall motion relative to the adjacent zone. You did this on purpose; however You overrode the default which is that for a moving zone the wall by default move with the zone.nSo your fluid is not rotating? and only the solid is rotating? As I said why not using sliding / rigid body rotating which will require interface connection.n
