April 21, 2021 at 3:11 pm
nI've had a combination of these errors:nSolver pivot warnings or errors have been encountered during the solution. This is usually a result of an ill conditioned matrix possibly due to unreasonable material properties, an under constrained model, or contact related issues. Check results carefully.nA solver pivot warning or error has been detected in the UY degree of freedom of node 718 located in SolidModel.1. This is usually a result of an ill conditioned matrix possibly due to unreasonable material properties, an under constrained model, or contact related issues. Check results carefully. You may select the offending object and/or geometry via RMB on this warning in the Messages window.nNot enough constraints appear to be applied to prevent rigid body motion. This may lead to solution warnings or errors. Check results carefully.nnIn real life, these pieces are like tabs on a composite piece experiencing loading and the bolts go through the tabs to mount on another piece.n
