RK
Hello, nThe max number of fluid cells occurs when the piston is at BDC. If you run such a case by starting at -180 deg ATDC, when the piston is at BDC, you can see the number of cells reported in FORTE.log. However, if you start the simulation from a different crank angle, then the cell count may be different due to snapping. For AMG cases as well, the fluid cells count is reported in FORTE.logn
