Sean Harvey
Hello @manoj55,nThanks for your question. Not sure if this will help since I am not answering how to get to the .fbx format, but one option is to use a 3rd party licensed tool like Adobe.nExport deformed file by Right mouse button on deformation results object in mechanical. Export to STL file format.nAdobe Dimension can read the STL of the deformed geometry and then easily render as desired. I have done this personally several times.nAdobe Dimension exports to Adobe Aero for AR experience ready to go. Not sure if it can export to a format you can use, but the desktop version does have export options.nHope this can help you to visualize your model in AR.nRegards,nSeann
