DrAmine
During property evaluation the solver requires input from the solution like pressure and temperature:so it might be the case that during iteration that you over the limits.nA loose table is not a good table. Moreover please use 21R1 as we have corrected a coupe of things . nPlease add as many screenshots of your model as you can: I do not have a crystal ball n
