Ram Gopisetti
Hi Array , The software is as good as you are and how you use it nOk looking into your case, Its compiicated to prescribe an single fix. But i gave a try but my model dimensions are in order of microns as i modelled. It worked as ease. the following are my results nI hope remodellign the RVE with exact measurements in units either microns or millimeters and select the same in the Material designer would ease your modelling nArrayfor your reference i am uploading my model, feel free to comment your response nCheers, Ram
