Erik Kostson
You should see similar behaviour on the force vs deflection curve to as shown here:nYou should see similar behaviour on the force vs deflection curve to as shown here:nSo in the link above see the force deflection curve in the last slide where results are shown - goes flat when reaching failure and then drops as it softens (one would likely see a similar behaviour for a 3 point beam test, that is failing in shear or flexural failure)nn
