Karthik R
Administrator
Hello,nIs this on a fresh instance of Fluent or does your WB already have a preloaded case file and you are attempting to modify and read a new mesh?nAlso, have you tried to reset the Fluent component? Does that work?nWhen you finish with your meshing task and close Ansys Meshing, are you able to right-click on Mesh & update? Is this operation successful?nKarthikn
