DrAmine
I recommend using 21R1 but 20R2 should be okay too (There were some issues which have been fixed, though). You table range is quite large: is this required?.nNow if RGP is still failing:n Stick to standard material properties and for phase change you can rely on PTL Table which is just Pressure Temperature Latent Heat Tale you provide under Evaporation and Condensation when using Alternative Energy Treatment or just just constant saturation temperature and provide SS Enthalpy at that saturation temperature.n
