Setting periodic in Fluent shouldn't have any effect on the meshing section. The set up looks OK from what I can see too. Fluent may create/remove some boundary labels/surfaces so you may be seeing a problem with Workbench workflows rather than the solver. If you export the mesh and then open Fluent outside of Workbench what happens?n
