1shan
Hello Array,nYou could try a simpler method. Create 1 single sphere using create> primitive and then use pattern to spatially distributed spheres in whichever way you like. Again use primitive to create a cylinder which encloses these spheres and select operation as add frozen. Next, use the subtract Boolean operation with cylinder as target geometry, spheres as tool geometry and set preserve tool bodies to yes. This way you will have each sphere and surrounding matrix as separate bodies.nRegards,nIshan.n
