You interpolate data into your current session so that you use them as starting data, however I did not test that from 3D to 2D: Just give it a try.nI guess it is cleaner to just run your second case from scratch.n
New Post - Reply To: Is it possible to import time dependent temperature and velocity field in fluent??
