1shan
,nA mesh should be just fine enough to give acceptable results thus maintaining a optimal balance between computational cost and accuracy. You could try using using a sweep mesh for the blade, there are special controls for sweep meshing for thin bodies. You could check those the help documentation Thin Model Sweeping (ansys.com).nRegards,nIshan.n
