It should be, TUI commands only change if different models are set, as you require extra inputs in some cases, eg turbulence settings for inlets. nI do suggest building the models using the GUI and then running via GUI/TUI as desired. It is possible (and easy when you know how) to build TUI scripts to set up the case but it's also fairly easy to make mistakes. For repetitive tasks (eg setting 1500 velocity boundary conditions) I use TUI scripts, for a model set up I'd nearly always use the GUI. n
