FERO86
This is Rayleigh-Benard convection problem, bottom surface is hot, top is cold, side walls are insulated. In normal rectangular cavity, height is taken as characteristic dimension. In this case also vertical height is the characteristic dimension, but how to chose the vertical height, iam confused.n
