Kyle
nI would place a time monitor in front of and behind the sample, to record the pulse before and after it interacts with the sample. The time monitors will return the electric field as a function of time recorded at their location.nYou could also use impulse analysis to determine the change in the time domain pulse:nWith impulse analysis you could run a single simulation, and then use the frequency domain results to determine the pulse shape for an arbitrary input pulse shape.n
