April 26, 2021 at 7:14 pm
不对,应该是nset(mode selection","user select);nset(selected mode number,3);n在添加模式光源后,模式光源还在选中阶段,可以用?set;查看所有可以设置的参数:namplitudenauto updatenbandwidthnbend locationnbend location Xnbend location Ynbend location Znbend orientationnbend radiusnbent waveguidencenter frequencyncenter wavelengthndirectionneliminate dcneliminate discontinuitiesnenablednfrequencynfrequency dependent profilenfrequency extrapolationnfrequency spannfrequency startnfrequency stopnimported indexnimported powernimported wavelength startnimported wavelength stopninjection axisnmaximum convolution time windownmode selection amennumber of field profile samplesnnumber of trial modesnoffsetnoptimize for short pulsenoverride global source settingsnphasenphinpulse typenpulselengthnrotation offsetnselected mode numbernset frequencynset maximum convolution time windownset time domainnset wavelengthnthetantypenuse global source settingsnuse relative coordinatesnwavelength spannwavelength startnwavelength stopnxnx maxnx minnx spannx0nyny maxny minny spanny0nznz maxnz minnz spannz0
