RK
Hello, nIt is difficult to pin point the source of error with the information you have provided. Reducing the URF's will generally help in convergence. However, sometimes, just changing the URFs will not lead to convergence. You will have to look at the model setup, the solution methods that you are employing to solve the problem, etc. The error basically is telling you the simulation is unstable. n
