Looking at the periodic panel the settings for pressure drop and mass flow are not available as parameters, expressions or UDFs. So, you'll need to do the run and report, alter the flow and re-run. If you don't initialise between runs it should be fairly quick. nGiven Re is a function of density and viscosity you could alter those using a parameter.
