April 27, 2021 at 11:11 am
Hi - I have not used this material model as it is very difficult for engineers to obtain material data for this material model (typically one will only have fc, ft, E, and v). (Not sure it is even 100% possible to use reinforcement option with DCP and microplane/CPT215 elements in the latest release - I think if they run the same model on the new release 2021 R1 it should not work - normally reinf264 and the reinforcements work with solid18X elements)It should be possible to use the Mentrey-Willam model and use the workflow I recommended:nHi - I have not used this material model as it is very difficult for engineers to obtain material data for this material model (typically one will only have fc, ft, E, and v). (Not sure it is even 100% possible to use reinforcement option with DCP and microplane/CPT215 elements in the latest release - I think if they run the same model on the new release 2021 R1 it should not work - normally reinf264 and the reinforcements work with solid18X elements)It should be possible to use the Mentrey-Willam model and use the workflow I recommended:nnAll the bestnnErikn
