Navya C
Hi,nLoss in a motor is design-dependent. If you do not know the internal design parameters of the motor there is no way you can achieve a proper heat flow model.nthere are numerous types and designs of motor that can produce 100-150W of loss. you must have the design parameters of the motor to properly estimate the heat flow.nRegards,nNavyan
