The UDM approach will mean you can plot the locations too. Simply using a sum method will give a number, ie the volume in your case that satisfies the IF statement. Note, determining if it's reached equilibrium will be difficult as simply setting a scalar range will pick up cells that fall into the limits and then immediately don't. n
