Hi Array,nThank you for posting your question. Doing this with DGTD is a bit harder than FDTD as the data is on an unstructured mesh. In FDTD, we can use image to plot the image and then export it with exportfigure.nTo do the same with the field from DGTD, you will have to interpolate the data from the unstructured mesh to a rectilinear grid using
interptet or
interptri. Once the data is on a rectilinear grid, you can plot it and export it in the same way as in FDTD.nLet us know if you have any question.n
