Aniket
Because of two reasons that are highlighted in yellow in the details:nthe part is a shell, and not solid. so the thickness is requirednmaterial is not assigned, so you need to assign the materials to all bodies with a question marknIf those are not shells, you need to modify the geometry to make it solid. You can use SpaceClaim (Fill tool) for that.n-AniketnHow to access Ansys help linksnGuidelines for Posting on Ansys Learning Forumn
