April 27, 2021 at 8:00 pm
nThe suggested solution to simulating a longitudinal MOKE surface was to take the example from this link (with polar MOKE orientation) and change the orientation of the source/surface instead of trying to change the MOKE orientation:nFor example, a plane wave source propagating in the y direction with a surface oriented in the x-z plane using the MOKE material from that example would have longitudinal orientation. This is simpler than trying to come up with a new grid attribute matrix, which can be complicated. However the user didn't reply, so I'm not sure if this worked.nLet me know if that answers your question.n
