Guilin Sun
The error message says that the E field changes its dimension during the sweep. I guess you are sweeping the geometry, so the mesh changes and consequently the E changes its matrix dimension.nnTo remedy, please add an override region to cover the possible region of a geometry change so to fix the mesh, and thus the E field matrix will not change during the sweep.nnBTW:Please make sure E field is necessary for the sweep.n
