DrAmine
That is just the Equation of state linking pressure to density and temperature. Has nothing to do if you are solving with density based or pressure based framework.nDensity Based Solver uses the density as the primitive variable. From it and using the EOS pressure will be derived. The whole conservation system is solved in coupled manner means continuity, momentum and energy at the same time (not segregated)n
