I have the similar issue. I have installed java and redhat-lsb and used -is:javahome and -is:log. Here is my log output. Please help thanks.
Log file created by MultiPlatform installer @Tue Mar 31 12:49:56 EDT 2020
INSTALLER_PATH=/home/chenniu/Shared/Electronics_201_linx64/Linux/AnsysEM/disk1/setup.exe.IShield
running inner launcher=/tmp/ans_tempdir_4131/istemp4145091124956/setup.exe.embedded -is
rig /home/chenniu/Shared/Electronics_201_linx64/Linux/AnsysEM/disk1 -is:javahome /usr/lib/jvm/java/jre/ -is:log /home/chenniu/Shared/log.txt -is:tempdir /tmp/ans_tempdir_4131
Log file created by MultiPlatform installer @Tue Mar 31 12:49:57 EDT 2020
INSTALLER_PATH=/tmp/ans_tempdir_4131/istemp4145091124956/setup.exe.embedded
command line switch -is:javahome is specified. Verifying the JVM with the JVM files specifed with the launcher.
JVM specified with -is:javahome cannot be verified with the JVM files specified with the launcher. Environment Variables will be checked next...
Checking the environment variables specifed in the JVM files to find the JVM...
No JVM can be found using the shell environment variable. Searching JVM will continue with Path Hints specified in the JVM Files...
jvm files not specified. Searching a JVM can not be performed.
Extracting bundled JRE...
checking disk space on the parition /tmp/ans_tempdir_4131/istemp4145091124957 for /tmp/ans_tempdir_4131/istemp4145091124957/jre-1_5_0_01-linux64.bin
49182 512 bytes disk blocks required.
66505240 512 bytes disk blocks available on the partition /tmp/ans_tempdir_4131/istemp4145091124957
Disk space check on the parition /tmp/ans_tempdir_4131/istemp4145091124957 succeeded.
137325 512 bytes disk blocks required.
66455912 512 bytes disk blocks available on the partition /tmp/ans_tempdir_4131/istemp4145091124957
installing bundled JRE...
Verifying... /tmp/ans_tempdir_4131/istemp4145091124957/_bundledJRE_/bin/java -cp /tmp/ans_tempdir_4131/istemp4145091124957/Verify.jar Verify java.vendor java.version
Verification failed for /tmp/ans_tempdir_4131/istemp4145091124957/_bundledJRE_ using the JVM file /tmp/ans_tempdir_4131/istemp4145091124957/_bundledJRE_/jvm
