Karthik R
Administrator
Could you please try the following?
  • Please remove all formatting from your write-up (by typing in 'Notepad') and paste the contents here. Sometimes, the site does not process stray formatting well.
  • If this does not resolve the issue, could you please try to copy sections of your post one after the other? Doing this will help locate the issue. Once you post, you can always use the 'Edit' option to make modifications.
  • If you are having an issue with posting an image, please post the text first and then post the image as a second post by hitting the 'Add Post' option. Please also try to change the file format of your image and try.
I hope one of these options helps you post your question.
Thank you.
Best,
Karthik
