Here is what I have in the Student License of SpaceClaim 2020 R1
The File Save As command is context sensitive, which means you get a different list depending on what is in your file.
When you have no geometry in your file, it gives you a short list.
When you have Solid geometry in your file, it gives you a longer list.
When you have a Facets, then it gives you the STL file format.
If you have surface or solid geometry, click on the Facets tab, then click on the Convert button to create Facets.
If this answers your question, please click the Is Solution link below.
