DrAmine
Gravity term is treated as source term. Once activated Fluent will redefine the pressure as documented in the Pressure Inlet description.
Theta is the angle between the wave front and reference propagation direction (the latter default is flow direction). Zero being the default
Vector U the referring the main flow velocity (background velocity) like you have 5 m/s of bulk water flow flowing in certain direction
