Thanks
Interior is formed when two blocks of mesh connect and have no effect on the flow: they're a place holder if you want to add something else (wall, porous jump etc).
What results are you expecting? The result you showed looks OK but you may be constraining the bulk flow by having too small a domain. Read up on wind tunnel blockage guidelines for advice on that factor.
