Your model should include the cylindrical support barrel below the bottom of the tank. The fixed support can be on the bottom of that cylinder and you can ignore the stress around the fixed support.
Your model should include the cover. The cover is flexible while a fixed support is not, so the fixed support does not give a good result for the stress at the top of the tank.
