1shan
You could try smoothing the mesh in the model especially in critical areas and also increase the load steps ( try with initial sub-steps steps 50, minimum 25, maximum 500). Also, is the mode shape deformation symmetric in compression and tension? If not you might get a asymmetric response.
Regards Ishan.
