turanyank
Thank you
I think I get some good results. Errors were between 2-6% compared to experimental results. But how can I get pressure loss? analysis was periodic so outlet is disappeared when I defined periodic.
10mm length and 10mm dia pipe, original length 1400 mm and 1200mm portion has constant heat flux 12752 W/m2
