May 13, 2021 at 6:14 am
Thank you very much for your answer. I am trying to do an explicit analysis now, to obtain similar results to your simulation. I am also using the same material with you. Now, I have done the simulation again by making contact definitions the same with yours by creating segment entities as you can see below.
However, the result is still inaccurate. I will also try to model this geometry in Ls-Dyna and perform the analysis by using shell section.
Thank you for your help and sources you have shared with me.
