May 7, 2021 at 7:21 am
If you have displacements and pressure in a csv/tabular format, you could import them as loads using 'external data'. You could check this video
" target="blank"> and follow the same methodology for importing displacements/pressure. Also check this section of help documentation for more details -https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v194/wb_sim/ds_imported_loads.html. Also, I am no expert in fluent or AQWA but it seems a bit odd that you are getting displacements in CFD. Is it the displacement of the wave front that you are talking about?Regards Ishan.
