May 8, 2021 at 11:51 am
ANSYS staff are not permitted to open attachments. In the future, insert the image into your post.
The distorted element error is because the velocity is step applied. That discontinuity is impossible to solve.
Use a 2 step solution. In step 1, ramp the velocity from 0 to 20 rad/s over 1 second, then in step 2, have the velocity be a constant value of 20 rad/s.
The images show different models: the first and third has a fixed and revolute joint, the second image has two revolute joints, the fourth has a single revolute joint. The correct configuration is one fixed and one revolute joint.
