Sri
Hi please try the following suggestions:
instead of slide control use manual settings under surface approximation and check. or
analyze surface mesh of the parts interested via modeler-->model analysis-->surface mesh. this can help you in finding the quality of the mesh surface. if the surface mesh feedback is good but still experiencing the error. Then reduce the model resolution under mesh settings and check.
Thank you.
