May 12, 2021 at 6:23 pm
Hi
May I know which version of AEDT are you using?
Also, could you describe in detail (adding screenshots would be better), after you copy+paste your source design to become the target design, what changes you made on the target design? Materials, boundaries, mesh operations, excitations, added geometries (planes, lines, etc), changed coordinate system, optimetrics, etc. ? Better to include everything you did.
Also, could you show screenshots for how you set magnetization computation in source design, and how you setup permanent magnet field excitation in target design (include screenshots for general, variable mapping, and object mapping tabs).
Also just want to double check or confirm with you that you copy+paste the whole design rather than copy+paste the geometry from one design to another.
