Greg Baethge
I think you can try and "manually" test ssh and scp from your local machine. To test ssh:
ssh -i
where is the path to the key (for example, /home/user/.ssh/private.pem) and the login information in the form user@host, where host is either the hostname or IP address of the remote machine.
For scp:
scp -i :
where is a file to copy to the remove machine, and the full path to the folder where you want to copy the file. Make sure the path is correct and exists.
