TrentE
However it is that you run lstc_server to generate the LSTC_SERVER_INFO file, you'll need to run the lstc_server with the server_data license file generated using the LSTC_SERVER_INFO file. If you run "lstc_server info" in one environment and you run the lstc_server with the newly created license file in another, that won't work.
