May 23, 2021 at 9:58 am
the issue is with the material used. You can choose Johnson cook simplified from the LSDYNA material model tab in the engineering data, but I hope it will not serve you the purpose.
After you do it , follow with the initial temperature set card to patch the bodies.
If you use workbench your node numbers has to be match as in the LSDYNA named selection Manager as shown in below
corresponding USER ID----------> use this in the commands.
The following image shows the outcome after the right material model and initial temperature is patched
The rigid bodies will have 22 degree followed by the billet 400 degree. Pay attention to model while using the Thermal Material model in workbench, it might be trouble to find the TMID to the scoped body.
Comment down for further help and post your results.
Cheers Ram.
*MAT_JOHNSON_COOK
$ MATID RO G E PR DTF VP RATEOP
2 2.700E+03 2.600E+10 6.890E+10 0.330000 0.000000 0.000000 0.000000
$ A B N C M TM TR EPSO
3.241E+08 1.138E+08 0.420000 0.002000 1.340000 582 298 1.000000
$ CP PC SPALL IT D1 D2 D3 D4
896 0.000000 0.000000 0.000000 -0.770000 1.450000 -0.470000 0.000000
$ D5 C2/P
1.600000 0.000000
*EOS_LINEAR_POLYNOMIAL
$ EOSID C0 C1 C2 C3 C4 C5 C6
2 0.000000 7.420E+10 6.050E+10 3.650E+10 1.960000 0.000000 0.000000
$ E0 V0
0.000000 0.000000
Cheers Ram.
*MAT_JOHNSON_COOK
$ D5 C2/P
1.600000 0.000000
$ E0 V0
0.000000 0.000000
