May 26, 2021 at 2:24 pm
The 'Coupled' method cold have been the reason for that error,maybe.
Since,the absolute pressure at inlet was constant with increasing inlet velocity. I tried parametrizing the total pressure of solid and liquid instead. Still had no luck.
Refining the mesh is only causing errors ,for some reason. And parametrised pressure does not change with velocity.
How do I obtain the pressure drop across the bed for different inlet velocities?
