icellb1
Hi
StrandedLossAC is reported when using Litz wire model. StrandedLossAC = StrandedLoss + AC eddy current losses due to proximity effects and skin effects of the litz wire. If you are using stranded type of winding, Maxwell by default turns off eddy effect, and this is also what's required for litz wire model. It could be that under your analysis frequency for litz wire, the extra AC eddy current losses due to proximity effects and skin effects of your litz wire is not obvious.
