George Karnos
You can post just the increment names.
What is returned when you run:
AnsysEM21.1/Linux64/mechanical/shared_files/licensing/linux64/lmutil lmstat -a -c 1055@licenceserver.edu
Also, any errors in the license.log on the license server?
Default path would be: /ansys_inc/shared_files/licensing/license.log
Just an FYI:
VENDOR ansyslmd 1056 should be VENDOR ansyslmd PORT=1056 if you want to use static port 1056.
