make sure all the beams share a vertex, and are thus all connected - then you can use multi-body parts in DM to merge all the common vertices and hence obtain a compatible connected mesh between beams (but first they need to share vertices).
multi body parts - so select all parts in the tree right mouse button lick and select form a new part
All the best
Erik
