ok -
in Fluent I set a wall-object as a System Coupling in Transient I tried both System Coupling Region and Fluid Solid Interface 1st Data Transfer: 2nd Data Transfer, Target participant list is empty:
New Post - Reply To: Export Pressure Field with Unique Node Id
